11.26.2008, 05:07 PM
You should make it a tow truck, have a servo actuated arm, and put broken trucks on the back section of the frame...
You and shaun should get together and make some money
hey wrecks em' you pick em'
Funny, I like that idea...
I think you should give me your rc's.
Hmm, I wil have to think about that...
Isn't the torque of that little motor incredible? So much in such a small package.
I'm sure you could up the gearing some if you want. Even with the additional weight and the additional drivetrain of your creation.
Looks great! Can I drive it? LOL
If you come down you are more than welcome to drive it!!! I actually plan to run a pair of 3905 chassis and use the new emaxx tranny with the super low 1st gear for crawling, and the std 2nd gear setup for maybe 25mph. The motor definately has plenty of power, no heat to speak of on either the motor or esc.
Is it a problem having the front steering being so much stronger than the rear steering?
It does have more power, but it is not that different. When I go to the 3905 chassis I will run 4 identical servos...
