BlackedOutREVO
11.28.2008, 11:56 PM
Yes, I am running direct drive. I want the 1250kv motor over the 1000kv because I will be running 3s and not 4s. I am pretty much ruling out the 1400kv motor now. The other guy who did the outrunner .5 used that 1000kv motor on 4s. The 1250 is higher quality and maybe a little smaller.
thats just to much motor
What size tires are you running? 3.5's or 4in tires? Either way, thats 35-40mph. With your other motor choices it will run hot. You can go for it if you want. But id reccomend you get a 1000KV motor, or run 770 on 4s
