brushlessboy16
brushlessboy16's Avatar
11.29.2008, 12:10 PM
im sure he can find something good for ya in the 4s 6000 - 8000 range and alot of the packs he can get are short in length which is what you need to put them both behind the spur gear/ centerdiff, if you really want the hot setup you could have him make you a couple custom size tray matching trays to run on each side in the back, would be a very nice setup and ultra secure.
I shot him an email to see what he says. 6200mah should get me through a 15min main without dumping, i want to know how they are getting 30 minute runtimes out of comparable packs. I still dont know what voltage to run... Length is not a problem, Matrix is a good 3/4'' longer then most truggies- even my zippy can fit behind the spur without a problem
Originally Posted by Rnemhrd View Post
Maybe this will help some. http://www.rc-monster.com/forum/showthread.php?t=16216 Maybe not.
It did help a lot but the difference between what people are saying makes me iffy. Since no one runs the same setup you know
