12.02.2008, 07:44 AM
It is personal preference IMO. Are you racing or having fun? For bashing 5s. For racing, 4s is really all you need, however, the higher voltage set up will be more efficient. (A 4k 5s set up is the same as a 4s 5k batt. ) Plus if racing w/5s, you always have the extra there if you need it. The drawback to the 5s set up is the added weight. You really cant go wrong with either set up.
If running 5s, you can find some batteries that are lighter to help save weight. Good luck w/your choice!
