Pinion Options
Bad Karma
Pinion Options - 12.04.2008, 07:46 PM
Info here - Colleted Adapter info
Available here - Colleted adapter
He makes high quality parts and it will not require you to grind a flat spot on the motor shaft, he also makes a one speed so you can use motor brakes and reverse, and just released a motor mount and I'm currently waiting on one atm
