speedracer1129
12.04.2008, 09:41 PM
Originally Posted by cheesecake View Post
you buy a used motor from me... come on here post your wonderful setup then when you run the motor over what its max rpm is and after you run it for more then 30 seconds in your paypal claim you want your money back......
you ran 1 run you had the carrier fail that would cause an abrupt shock on it and damage the bearings in the motor. i should not be responsible for you not running the motor within its specs. i ra the motor on 5s without any issues.
The motor was never ran out of it's specs to start. As previously stated, the motor was already giving problems on 5S and with no load so that says something. I may have made the mistake to have intended to run it after seeing that happen, but I had no reason to think there was any problem with the motor.
