12.06.2008, 06:15 PM
Your servo is centered via radio trim, or through the linkage? Center it via the radio, and then tweak the linkage so everything is straight.
FYI: When setting the EPA, you should start at something like 60%, turn the wheel full one way, and increase the EPA until the steering locks, then back off a notch or two. Repeat for the other side. This provides the max steering throw without damaging the servo by having it try to fight against mechanical limits.
