DM-1 Spec brushless conversion
dangerwr
Lightbulb DM-1 Spec brushless conversion - 12.10.2008, 10:28 PM
Originally Posted by ssspconcepts View Post
Hey all,
I just ordered a DM-1 Spec and some other stuff to begin my build. I am planning to use a MMM, Neu 1515 1Y, and 5S or 4S FP 5000mah. I am looking for recommendations on the following aspects of the build:
Should I use the stock 2-speed, 1 speed spool, or center differential? I have a spare set of front/rear/center spider 8 diffs and I am considering using these. What do you think?
I will be out of town for a couple of weeks but will post many pics when I return.
Thanks for taking the time to read and reply.
Greetings,
I have been searching the internet for anyone else converting the OFNA DM-1 Spec to brushless. I am planning to do the same this winter! Apparently the drive train is the same configuration as the Jammin' X1 buggy so immediately I thought of Novak's conversion kit. The problem I was wondering was the same as your question #1. What to use for a center diff?
I figured I would use a single-speed and did not know if there was a choice between a solid and a spool. I know OFNA manufactures a single-speed solid diff I believe they use in the Ultra GTP kit setup for dirt oval.
I would love to see pics of your conversion and will subscribe to this thread. I use a Neu 1512 2D and the MMM v3 in a Losi 8ight conversion but was thinking of using the Novak HV 4.5 in the DM-1 spec.
What are your thoughts on the battery tray? I am wondering if I will need to fabricate one or retro-fit the RCPD tray or use the Novak's somehow. The chassis is narrow on the DM-1 and would like to balance everything as best as possible. Cheers!
