Pins Pins Pins.
JERRY2KONE
JERRY2KONE SUPERMAXX
JERRY2KONE's Avatar
Pins Pins Pins. - 12.11.2008, 05:34 AM
Send Bill at RCAlloys an email and ask him how much for some spare pins. He makes the dogbones and can sell you a few I am sure. That way you have the exact replacement in case you run into this again donw the road.
Originally Posted by jordan... View Post
So im having a hard time finding a replacement pin for the cvd. I was going to use a drill bit, but then found out that the shank, the end bit, is not hardened steel. Do you guys think that it will hold up if it is just plain old steel, not hardened steel?
