ssspconcepts
ssspconcepts's Avatar
12.11.2008, 05:52 PM
Just so y'all know...I just got back and tried o drop in the center spider diff with the 46T spur and ran into a few problems:
1) the Jammin CR motor mount doesn't sit quite high enough to accomodate the spur. I have four options to correct this (a) dremel a little material around the chassis spur gear opening (b) try to find a smaller spider spur gear (c) Swap the CR mount for my CRT (d) insert some spacers or washers in between the chassis and center diff assembly
2) The front center dog bone is 88.5mm and the rear center is 104mm. When I switched the 2-speed for the center diff, the front center dog bone was too short. It looks like the 104mm dog bones (front and rear center) would fix this issue.
Brian,
Do you have a link to the center spool you mentioned? Part numbers?
Thanks.
