MetalMan
MetalMan's Avatar
11.21.2005, 10:20 AM
A balancer can be hooked up like that, if that is how a particular balancer works.
Ususally, you plug the battery into the charger like you normally would, and then you would plug the battery's multi-pin connector into the mating port on the balancer.
If you still need explanation in the form of a picture, just ask :).
