Savage03
12.15.2008, 04:58 AM
I see some use a bec from castle, do I need this also? Just realized after locking the tranny into second I wont need the manual brakes so I can now remove the brake servo.
I have read some were worried about the servo plate and only having the 2 screws holding it in place, after looking I to would be a little concerned but I have very simple fix, something FLM should have looked at I think. Take a crossbar that you use between your tvps and you will have to make holes to match on the servo plate then lay it on top of the plate and it will screw into the plate since the holes are threaded, then you will need to drill a hole on each side of the tvps and there you go nice and strong. I will get some pics that will show it much better its bedtime.
