11.21.2005, 09:21 PM
Cool... are you sure you have the 5995, and not the 5955? I have seen others confuse these two, becouse they are so similar.
..., and featuring an exclusive "pivot" mount, the Hitec HRS-5995TG servo also rotates 180 degrees compared to the traditional 75 degrees most R/C servos travel.
...when you choose to use Hitec digital servos and the new HFP-10 Hitec digital servo programmer and "all brand" servo tester. Our HFP-10 will fine-tune all your Hitec digital servos for optimum performance and is the perfect answer to "matching" sets of servos for those big planes.
Programmable Features include
Reset to factory default
End and center points
Direction of rotation
Dead band width
Failsafe point
Speed (reduction only)
It's a servo and transmitter tester too
Use the HFP-10 as a servo tester for any brand of servo. It displays transmitter pulse width, voltage to the servo, and has both an auto and manual servo travel function. The HFP-10 is housed in a solid aluminum case with a 4.8V. rechargeable nicad internal battery, uses an easy to read LCD display and is a great addition to the extensive Hitec digital servo product line
