bustitup
12.18.2008, 11:00 PM
i was told by neu NOT to use it in a car at all, i suggested about using a filter on the back and they still said NO, plus the can has a 50mm outter diameter and are alot longer and heavier too.
if you need a 1515 buy one from mike i talked to him to today and he as a couple 1515 2.5d finned cans he got in yesterday.......no need to buy that heli version, its made for a clean air environment not dirt.
Ok I called Neu today about this and they said it would run in a car just fine....but I did a little reseach and compared the specs here is the only two differance I found
the non H motor
ohms is 0.01
Io@10v is 2.25
the H motor
ohms is 0.091
Io@10v is 1.1
can someone decifer that for me? Brian?
