George16
Supermaxx
George16's Avatar
12.20.2008, 01:38 AM
Shark413, I have about 5 sets of Ofna diffs/gears that I can throw in there if the stock ones get sheared. With that said, I will also have to change my spur/pinion since the ofna diff I have are from the buggies which use a 43/13 ring gear/pinion.
Well see how the stock goes. I'll just have to change back to 10K for the center since I put 30K in there. I like how it's setup now but there is always room for improvement.
Thanks again.
Edit-I also installed the HB hardened gears in the CD.
Predator with OS .21TM
Supermaxx with Mach .26
Revo with OS .18TZ
Kyosho ST-RR Conversion
