Ryu James
Ryu James's Avatar
12.22.2008, 07:01 PM
it looks pretty nice but is there a way to move the item you are milling or do you just have to use your hands? if there is a way to clamp down the chassis and then move the entire table in any direction (by turning knobs or something like on a lathe) this will result in much straighter cuts. i know moving it around by hand to mill out an area is tough to keep straight. i will say this though. milling carbon fiber is 100x easier than milling alum. you can see the milling i did on my CF chassis with just my dremel. not super clean but not bad. i tried the same thing on alum and just gave up. a real pain in the ass with a dremel.
chassisfusion1
Jammin SCRT10 Neu 1512 1y
