Thread: stampede bl
RCcarnut
11.23.2005, 07:28 AM
Even if you do get the motor to fit you will need a new controller also for your pede(maybe you new that).
Plus an aluminum idler gear. After that all you should really break is stub axles and spur gears as long as you don't hit anything at 35mph;)
You are looking at at around $300+ for that kind of setup.
A 380 size motor would probably burn up in a pede. Pede's are fairly heavy and even my Novak SS on low gearing it overheats sometimes. When I had a lehner 4200 basic in it that got very hot also.
