12.26.2008, 11:51 AM
Another note: The two speed setup will not have reverse...
But it will make cool shifty noises and most likely cause the car to do really sweet sideways drifts when 2nd gear kicks in under full throttle!
I can say that Mike's 2 speed adapter is very nicely made and will work great on a 2 speed conversion like yours. I have a hb 2 speed car in the works and I plan to run his adapter. I have used it for mock up purposes and the fit and alignment is perfect.
Only issue with novak's conversion is that you have to use a novak hv motor (may not be enough motor for your intended gearing/speed), and I dislike the battery trays. My advise would be to stick with mike's parts, your finished product will be alot better with his stuff. Plus all of us here can help you along the way!
