Originally Posted by lincpimp
Well, stick with the robinson or rcm pinions. I bought some novak 32p pinion and they are huge, very wide, to the point that they will not fit most of the motors I have. They either completely miss the spur (stick out too far) or touch the front of the motor...
Honestly their material was questionable too. Stick with the rcm or rrp hardened pinions. I run my savvy with those pinions and a plastic spur and it does fine... I will most likely put the flux tranny on when it comes out, just to simplify the setup.
+1
That metal spur gear will actually make more noise. It won't strip and as long as both it and your pinion are properly hardened it shouldn't wear out but it'll be louder than a delrin spur gear. I'm thinking that noise is mostly just the motor.
