lutach
lutach's Avatar
12.30.2008, 11:42 AM
I find it strange that only the Mamba Monster is having this problem. This might also have been the cause of the Schulze ESCs to go up in flames as well. I haven't heard this happening to any other brand of ESC (I might be wrong). There's got to be something else causing this problems. You can't just blame the batteries. I had my Schulze go up in flames, but with the same set up no other ESC has done that. Even though the Zippys might use lower grade lipos they are still better then NiXX, so will the Mamba Monster fail all the time because the NiXX can't supply enough current?
I'm just curious as I still haven't used my Mamba Monster, but I would like to know if something else is causing the problems.
