e-rev project
12.30.2008, 02:55 PM
Originally Posted by Gee View Post
I had the same issue recently with my flm HV Maxx. Wasn't the diffs that were flipped it was the transmission was installed backwards. Mine was a little more obvious. Going forward made the maxx go forward but it wasn't as fast as normal and the brakes were instant reverse as fast a forward was normally. Like coming back right at you jump out of it way fast. But I couldn't hit the brakes when it shot past me into the fridge because pushing forward made it go faster.
when you say "installed trans backwards" do you mean the gears or the mounting into the chassis? i was not aware if you could install the gears backwards, if that was the case.
