Thread: Clod Build...
01.01.2009, 10:02 AM
I'm failing to understand the direct bec power. Were you worried about frying the rx?
Yes something I picked up on the crawler forums - With the amount of amps 2 7955s would pull with the heavy tires - 10z lead in each front 4oz in each rear - apparently the spektrum rx's can go pop.
It was a bit of extra work to make up the connections but nothing that isn't reversible and if it saves my rx it seemed like a good idea.
