01.01.2009, 03:14 PM
I get that error near the end of a lipo charge when the voltage gets to ~4.1v/cell and the charge rate is anything over 3.8A in my old EOS7i. If charging a 5Ah battery, I have to manually reduce the charge rate near 4.1v/cell to keep the voltage there until it is set to 3.8A. I took the charger apart and there is no tweak adjustment anywhere. Nothing I found fixes this unless your charger maybe has upgradeable firmware, you'll have to return it.
