01.02.2009, 12:30 PM
To keep the pinion on i find a little dap of blue threadlock works wonders, though I keep thinking that if you could put a groove around the tip of the motor shaft, you could slip an e-clip on there and even if the pinion came loose, it wouldnt fall off the shaft...
