01.02.2009, 12:46 PM
Originally Posted by TwzteD View Post
what do you think would get more speed out of?
The lipos you linked to will only be good to about 40mph. So the gearing I suggested will be about it. If you want to gear up you will need to go to a better lipo, such as the fp 45000 30c 6s that I run. Bit those are expensive 2-3x as much as the zippy...
Either setup you mentioned will be able to go fast, your electronics will be the limiting factor (and driving skill)
