01.02.2009, 05:01 PM
Originally Posted by pedeboi364 View Post
mech brakes grab way harder=mor control and less ESC strain
Firstly that wasn't the question - Apart from front rear bias - that is tosh about grabing harder and more control... ESC brakes on a modern ESC such as the MM and MMM are infinitly variable in both strength and profile...
You can easily lock up breaks on a 12-15lb MT with a MMM and ESC brakes do not suffer from fade.
Agree and noted above that ESC braking puts additional load on the esc - but provided you are geared correctly and have the appropriate setup this is not an issue.
