redshift
RC-Monster Square Tube
redshift's Avatar
01.02.2009, 07:51 PM
lol have you heard about the recession.. I had to vote for that one
My truck is down to bones at the moment pending some suspension changes, and it's been a hard run on things the last few weeks. The first was when I wadded my 2mm screws for the rear ringgear and then I sheared the 2nd gear input pin..... so a did the 3mm oversize with the rear and the drillbit replacement for the cotterpins on both 1st and 2nd gear, and on a spare as well. Kind of a pita but well worth doing. and lastly I nearly lost a cvd pin on my rear centerdrive, so I went thru and ground flats in the center on the pins in all 6 of my cvds. And loctited the snot out of em.
Suffice to say I probably won't be makin it, I have a few tricky ideas for changes to my truck, and this is my only rc aside from my plane :(
Hope you get a good bunch together- shouldn't be a problem wih the members at RCM :)
