01.02.2009, 08:31 PM
Originally Posted by mohanjude View Post
The 20kg is due to the weight of the lipo cells - I had 2 banks of 10S 6000MA - which works out to 37V @12000MA.
I also going to shed all the alloy including the alloy rollcage.
Thanks for all the tips - the motor is a Lehner 3080 /9 -> the amp draw was with me trying to stop the shaft with my fingers using a Leather glove. I would not let a motor just simply rev full blast. I must say my thick leather gloves got very hot!!
The bottom line is that I have taken the Lehner off the truck put the Bolido in their shed some weight by taking the heavy aluminium rollcage and only running one back of 10S 6000MA lipos. The trucks appears to run well and I will post some videos shortly. I will weigh the truck and give you the correct loaded weight including batteries.
Mohan
Wow, that is alot of lipo! Anyways, sounds like you cured the issue. From what othello says the esc just does not like 2 pole motors... Seems weird to me.
Glad to hear that you did not let it run unloaded! 10s 6000 should do fine, loosing the weight probably helped too.
