Originally Posted by Ryu James
and mech brakes are definitley more efficient for your motor. with mech brakes you can have braking and reverse set to 0% so your motor is not working at all when you brake.
Huh? The motor isn't "working" when you brake, it's using the battery as a load and dumping the power there. Your argument doesn't make any sense.
FWIW, I've tested this with my eagletree and I can see amperage and voltage go UP when I brake, which is proof positive of regen braking. Think of it this way, if you didn't use regen braking, where would that energy go? Where's the load to dissipate it? Surely not through the FETs. It's regen.
