MetalMan
MetalMan's Avatar
11.25.2005, 02:31 PM
Since Mr. Constructor was the one that recommended that controller, it should be fine. It can take 160amps continuous, which is a LOT. It can take higher peaks. If you could get a fan running over it, it should be fine. You would have to cut the heatshrink and using thermal epoxy to get a heatsink on.
