shaunjohnson
i pwn nitro
shaunjohnson's Avatar
01.06.2009, 02:42 AM
sleebus,
the egle tree probably shows a voltage increase when braking because voltage drops under load...as soon as you get on the brakes the voltage is probably picking up what it was losing under load
but if the voltage spike was above it's "resting" voltage then i guess you are right
  Send a message via MSN to shaunjohnson
