crazyjr
crazyjr's Avatar
01.08.2009, 12:14 AM
Originally Posted by TexasSP View Post
Was looking back and although I have never used a quark, I always have heard good things about their power delivery. However I think some of the advantages that can be brought via the Novak HV can also be had via the MMM/MM without the disadvantages of the Novak system. With the ability to change so many parameters of the MMM in regards to start up, timing, braking percentages, throttle curve, and braking curbve, I think it is fairly easy to come up with an optimum setting for each situation. I can personally testify to the smooth startup of the CC firmware in the new MMM and MM and find it every bit as smooth as any of the Novak's I tried.
Keep in mind I am not dogging you for using the Novak, I am only criticising what I believe are faults of Novak as a corporation. I think eveyrone should use what ever suits them best and/or they like the best.
No worries, Everyone has an opinion, I just never had the problems with my novak that everyone else has had. I also agree that the novak wasted the opportunity, to be on the forefront. With all they brought to brushed racing, you'd think they should be the leader of the brushless movement. However, at this time, they are often last looked at
