11.26.2005, 05:17 AM
If you want torque, you need to get a XL size of wanderer (about the same as Feigao), Mike can get them. You can gain lots of torque by gearing the truck a bit taller and use a higher KV rated motor. that XL is made till 625 rpm/v rating, they cost about 100 dollars. they are powerfull for sure.. How long do you want it to drive? gearing it higher, makes you able to drive a bit more precise
