himalaya
himalaya's Avatar
01.09.2009, 02:21 AM
FWIW, if you ever need to figure out how many poles an inrunner motor has; Remove the rotor from the can, roll it on a flat metal surface, note how many times it "sticks" in one revolution.
Actually you can know the pole number WITHOUT OPENNING the can.
Just rotate the motor shaft, feel how many "detent" in a whole 360 degree round turn.
2-pole rotor will feel 6 detents, that is, 2 polesX 3 stator phases= 6 sticky positions.
4-pole motor will feel 12 detents, same rule, no matter it has a slotted stator or not.
....What a Blue Sky....
