chrismechanic
01.09.2009, 06:17 PM
Watercooling is just a bad idea for vehicles.
well no the reason a car has water cooling is the surface area on the engine can not dissipate the heat fast enough so the water carrys the heat to the rad.... which has 5 times maybe more surface area as you said. but i hope my motor wont have an internal temp of 450 degrees or so. so im not going to water cool my maxx for that reason. if set up right it dont need water cooling
