Thread: Team Infinity
ssspconcepts
ssspconcepts's Avatar
01.10.2009, 11:04 PM
Okay...so I ordered a set of these tires from Team Infinity off of Ebay. It was a heck of a deal...a full set of glued slicks shipped for about $22. When I got them I was pretty happy with the quality and the clean glue job. The rubber seemed to be pretty good quality for the money too. So I took and mounted them on a BL Ofna Ultra/Dirt Oval that I have been building. I also installed a MMM ESC, a Neu 1515 1.5D motor (2700kv), and 5S flightpower battery, with a 15T pinion and a 51T spur for gearing. I ripped up and down the street a couple of times and then I decided to see what the car was capable of doing. This was the result of what happened when I went full throttle Ya shoulda seen it...foam and rubber blew EVERYWHERE:
From Ultra
What are your guys' thoughts? I have a similar setup in my DM-1 Spec except I run Ofna factory tires and I have not had this happen. Do you think I just got a bad tire or do you think my set up was a bit ambitious for glued tires? Does anybody know of a company that makes 17mm hex hub beadlocks for buggies?
