Thread: hyperion duo
01.11.2009, 02:45 AM
The lower the number the more "ideal" a battery it is. "m" is milli, so they are 0.04 ohms. Not bad. Battery resistance is not linear though, meaning the resistance will be a bit lower at the high currents. If it was a flat 0.04ohms for any current, the voltage of a 11.1v pack would drop to 7.1v @ 100A. The best way to gauge a battery's performance is to graph it real-time under the heavy load. But, at least this gives you a relative idea compared to other packs...
