drkdgglr
01.11.2009, 04:57 AM
Would like: 135-140mm long full extended to 95mm fully compressed (40-45mm throw). From 24mm to a max of 34mm diameter.
Are there any shocks out there that fit my "Would like" requirements?
Just measured quick and dirty(so I might be off a few mm's):
LST2/ Aftershock shocks:
pin to pin: 146mm, compressed: 106mm
shock body diameter: 25mm
Muggy shocks:
pin to pin: 133mm, compressed: 104mm
Cen gst 7.7 shocks:
pin to pin: 143 mm, compressed: 115mm
shock body diameter: 17mm (piggy back shock)
edit: I snapped a Muggy shock shaft yesterday. They're notoriously weak. The LST2/aftershock ones can be upgraded with TiNi coated shafts(as mentioned before). You can find plenty good deals on these shocks on ebay. The plastic aftershock shocks will be cheaper than the alu LST2 ones.
