Gee
A Horse's Ass
Gee's Avatar
01.11.2009, 05:04 PM
Thanks. I will order the front/rear for the crt and use it for the center cup.
I had the problem prior to this mod with the screws. The holes in the differential were stripped and the screw couldn't be tightened down. Even with a longer screw they would just turn and not hold in the cup. Is that the same problem you had when you did the mod?
The other option to run the plastic spur is not perfect either but will work if done correctly.
