01.12.2009, 06:00 PM
The 1st gear set will not work with the gmaxx single speed plate. The idler gear is in the wrong place on the 2nd gear side of the case. You can just lock it in 1st and replace the 2nd gear gears with spacers. Or just remove the idler on 2nd gear. Use some screws and attach the sliding dog clutch to the 1st gear output gear.
