sikeston34m
sikeston34m's Avatar
01.16.2009, 02:28 PM
Originally Posted by asheck View Post
Maybe someone on here knows.How did the c ratings come to be used as the standard?Why do they not just use amps?I think it would make our lives so much easier if they said ,100amps constant for 5000mah,before hitting a 3.2volt cutoff.
I believe this is because they want us to understand a couple of things.
Amperage output is affected by capacity for a given "class" or C rating.
A 20C 4000mah pack will put out 80 amps continous where as a 10C pack will put out half of that. You can play with the numbers but the formula remains the same.
To obtain a higher C rating, manufacturers use a greater anode/cathode material to Electrolyte ratio. This is why the higher the c rating, the more they weigh for the same capacity.
It's the use of more Anode/Cathode material in the higher C cells that increases the cost.
I believe most manufacturers don't falsely rate their cells. This is their reputation. But............then the product gets passed to the retailer. It then gets "labeled".
I can just imagine some thoughts like:
Most users won't push these that hard anyway.
The RC Electric setups on the market can't handle more than these put out.
If we charge more, the added profits will cover warranty claims for those that do push them. It's only gonna be a small percentage, plus we can blame it on their setup and suggest larger more expensive packs that we carry. More Sales! It's a win-win.
In the beginning of the "transition" from Nimh to Lipo in the RC Industry, I believe this was pretty easy to get away with.
It's getting tougher, as the market competition increases. The average prices are dropping and the cells are getting better.
