JThiessen
JThiessen's Avatar
01.18.2009, 02:50 PM
Great job with the website Shaun. Need to end up with more pics of the chair, and you could use a good wordsmith'ing on it (I noticed quit a few grammatical and spelling errors as I was reading through it). If you want, I can copy and paste the wording into WORD (or program of your choice) and provide the fixes - but I didn't know if you were already going to do that.
On a technical side. I noticed in some of the pictures that the front caster mounts are not normal to the ground. This will result in the wheel tending to remain with the caster lead (distance between the centerline of the wheel and the centerline of the swivel) facing toward the front of the chair (did that make any sense???). Did you notice that at all with your testing?
