cdis
01.20.2009, 09:43 AM
A smaller diameter brake disk wouldn't help would it? What would be more helpful would be either thinner brake pads? Then the motor would fit "over" the top of the end of the screw that holds the brake pads together, which you can see is touching the front of the motor, and hindering it from moving any further toward the spur.
