dangerwr
01.21.2009, 04:03 PM
Originally Posted by finfin View Post
Thank you very much... Dangerwr and ssspconcepts...
To compare Dm1 and Gtp, which one is better for concrete street with brushless power? and which one can i get higher top speed if i use the same brushless power? I'm very newer for on-road...
Thank you for advance... guys....
Well, I prefered the DM-1 over the GTP and had the same use in mind. There are racing classes for both, I guess, with the GTP maybe a little more popular. That being said the DM-1 cars are a little more "purpose built" for on-road racing. If you have a smooth concrete or asphalt to drive on I would definitely opt for the DM-1.
I do not race but have access to huge parking lots that are very smooth here in Denver. I like to bash, so to speak, with very fast brushless cars that handle well. One thing you might consider is that since the GTP is based directly off the ULTRA buggy you will have a few more options when converting to brushless. This is my 2nd brushless conversion so I decided I was ready for the next level of challenge. The DM-1 cars may require a little more research and fabrication but that is why these forums exist (to help with those type of things!).
If you want an car that is easier to convert and have rougher pavement I would go with the GTP. If you do not require a complete out-of-the-box brushless conversion solution and have a nice track or smooth parking lots than I would recommend you get yourself the DM-1. Keep in mind there is both 1/7th and 1/8th DM-1 cars--look through the early pages of this thread and you will see.
Lastly, go to youtube and search for Kyosho GT2 or Ofna GTP and watch how those cars handle and see if you like what you see . . .
