01.22.2009, 01:29 AM
Originally Posted by joeling View Post
Hi lincpimp,
This is good info. I had some issues with the Spektrum receiver not powering up. I thought it was the receiver & installed a cap to smooth things out. So, it's the sidewinder internal BEC. Will have to do something about that then.
Regards,
Joe Ling
I had the exact same issue. At full servo throw in either direct the spectrum rec would switch off. I tried the cap on the rec, but that did not help. The ccbec has cured the issue and I have a few hours on the truck with no issue. I would like CC to make a sidewinder crawler model esc with a built in ccbec, including selectable voltage output.
Great esc, I have 4 of them for my crawlers, and for the price you can't find a comparable model, hell the closest esc that does as well is the MM!
