eovnu87435ds
A 16yr old with a combover
eovnu87435ds's Avatar
01.25.2009, 02:15 PM
i personally use the turnigy accucell 6 cell lipo charger. software is fairly easy to use, and it was only 40 bucks... it charges and balances at up to 5 amps, provided your power supply can put it out. i charge my rcm lipos with it, and when i test with a volt meter all cells are perfectly balanced after its done charging. I use a computer power supply, it is fairly easy to make and all you really need is the correct end(or alligator clips) and you're done. just take your supply, cut off the big plug at the end. for your adapter, use yellow wire as positive and black as negative. then to turn on simple touch the green wire to any black, or solder it to a switch if u really wanna be fancy. viola
Hyper 7
BARBIE JEEP!!
CRT.5
TC4
RC18B
