SpEEdyBL
"Out of spec" enthusiast
SpEEdyBL's Avatar
01.26.2009, 04:52 AM
Originally Posted by hagenmi1 View Post
So is powering an RC8t with the 2200 way overkill? I like the 2650 but I would rather have more motor if I decided to go over 4s.
Put it this way. If you gear the 2200 with a 26 tooth and you gear the 2650 with a 22 tooth you will practically get the same results. Not that you would ever gear that high for either motor, but you get the idea. I have a 2650 kv combo on the way that i will be running on up to 5s. It's the same rpm as the 2200 on 6s so I should be fine for my intended use...
...of showing off in the parking lot for 20 minutes straight that is. lol.
Area 52 Ranch Raceway
T.R.C.R.
