mikey09120
RC-Monster Stainless Steel
mikey09120's Avatar
01.27.2009, 01:00 AM
Originally Posted by E-vil Maxx View Post
Ok so im converting my slayer to vxl brushless I will be running a maxamps 3s lipo, I would like to know if there is a way to get rid of the mechanical brakes, and use the motor brake I also want to keep it 2 speed. Also what gearing would you suggest. I would also like to get rid of the clutch bell and run it direct with a longer pinion. Thanks
honestly, a VXL does not have enough power to push a slayer. a medusa 70mm 2000kv with a MMM on 4s-6s is the cheapest setup and has awesome temps and power, you get what you pay for. i would also not recommend purchasing maxamp as many believe they are overated and data supports this. try a couple 30c flightmax zippys http://www.hobbycity.com/hobbycity/s...1&ParentCat=85
also. do you have a conversion kit?
idk about motor brakes with two speed. but locking into 2nd is the best option. why do you want two speed?
-mikey09120
