Serum
Serum's Avatar
11.29.2005, 05:03 PM
Hi pwnd, i happen to know you from the rc-racingcars, if you use the same username on those boards?
The most important thing to modify to your savage is to get your diffs beefed up. AND your drivetrain.. (depending on the amount of power your planning of using) FLM is currently making a bulkless setup for the savage.. About the transmission. i would use a savage 3speed. It's beefy for sure and it would make the conversion a tad easier as well. (shoot for yourself, i personall don't fear a bit of work...). Eversince it's a truckzilla, with bigger wheels as well, i would seriously beef up that drivetrain. Don't expect the 14mm truckzilla wheels to last forever though. They will die on you pretty quick.. 23 mm is the key to succes with a heavy BL powered savage.. (or good RPM rimms, though they won't last forever either)
