MetalMan
MetalMan's Avatar
01.27.2009, 03:55 PM
If you were to take full advantage of that charger, you would need a 360watt capable power supply. To be on the safe side, a 30amp power supply should be used. Most hobby power supplies put out 13.x volts, so a 30amp could do 390watts, which is good because it will account for charger inefficiency.
